跳转到主内容
加入维修社区 - 创建账户
MacBook Air 13英寸机型的维修指南,支持手册,以及疑难解答信息。
Mac Won't Read SD Card
Hi all,
My Mac is not reading an SD card from a digital camera. The card appears on neither the desktop nor in finder. The card works fine in my camera. Any ideas on how to fix this?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
5条评论
Was the card reader working before or did you start having issues only recently?
完成的
In the past, it has worked fine. I'm fairly sure I was using the same SD card, too. This problem only came around recently.
完成的
Can you clarify what model you have so we can guide you to the needed part you'll need to fix this.
Plug your systems serial number here: EveryMac - Lookup then paste the systems URL so we can see what you have.
完成的
I'm having the same issue using my Finepix AX camera, trying to see pics from my Bushnell Trophy cam game camera. Mac Air C02HVR43DRV7
完成的
2 days ago I faced a similar іѕѕuе, my Macbook pro stopped reading my SD cards.
I tried I tried everything and nothing worked.
Finally I managed tо fix this problem after getting help from Apple Mac Support
Follow the steps here: http://bit.ly/MacSDcard
It should solve the issue
Goodluck
完成的
添加一条评论
2个答案
已选择的解决方案
I restarted the computer and the card is now read... guess I probably should have started with this :/
这个答案有帮助吗?
得分 2
添加一条评论
Make sure the contacts on the SD card are clean, use a CLEAN pencil eraser and lightly rub the gold contacts. If that doesn't work you might need to open it up and clean the internal contacts.
Alternatively; try another SD card
这个答案有帮助吗?
得分 1
6条评论:
Already did so. No change.
Have pics on THAT SD card..
完成的
Have you restarted your computer?
完成的
try opening the SD card on another computer. Then copy ur pics, and paste them on another NEW SD.
完成的
Why did this work? I have no idea why just rubbing the goldie shiny bits of an SD card would make my Mac accept it. I mean... I'm not the only one, right? I didn't even use a pencil, i just casually rubbed it on my shirt and tried again. It worked though!!! I think there's something in the water, the communists are projecting vapor waves at the moon, my grandpa turned of the sports to watch anime, cats and dogs living together; mass hysteria!
Bottom Line: it worked, and I'm mad at myself about it.
完成的
@C Smith
did you try using a pencil? apparently it works.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 111,480
