跳转到主内容
Office inkjet printer released in January of 2009. Model number G510n.
20 个问题 查看全部
Broken gear tooth in scanner
Hello, I noticed that whenever I turn on my printer, it makes this very loud banging sound. I managed to narrow it down to a broken tooth on the rack the scanner light goes across, as shown in the picture. Is there a way to replace it or get it repaired? Also, this isn't the wireless model, but there is no device listing for the plain one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I'm not sure about replacing the part, but the answer in this thread (Which glue will work best to repair plastic dome lid locking part?) has tips on repairing plastic things. It's easier in this case as it's not food-related, so the options to glue it are much more abundant.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the reply! Not sure that that helps though since there isn't really anything left to glue back in place, it looks like the tooth just disintegrated over time or something, as it is the tooth that the light bar parks on.
完成的
I see. You could rebuild it with the liquid plastic welding stuff. Otherwise, you might try some Sugru: https://sugru.com/ or [关联产品丢失或禁用: IF145-171].
Though I'm not sure how well Sugru would do on such a small thing.
完成的
添加一条评论
添加你的答案
da stumer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 313
