I can scan and copy but the printer won't print
Just connecting new brother Printer through wifi. Both items are receiving wifi but the printer won't print from the computer. It scans and copies.
1.) If you search for the printer, with the WiFi on BOTH items signed in on your Apple and if you don't see the printer then you must either check your printers installition instructions under your Apple product for what you need to finish the set up
2.) Have you installed or downloaded any software downloads from the manufactures website that might be required to allow the two devices to communicate? Scanning is done from the printer if I'm thinking correctly as to what you stated ? The scanner came as apart of the printer, the printer, & your apple item need to be connected with all the correct Drivers, and software downloads required by your model of Apple product.
This can be a like trying to eat spaghetti with a spoon. If you don't find the clear easy set up, I'd strongly suggest calling the printers help line and get a Tech to walk you through set up. I'm fairly good with set ups, but adding a NEW wifi printer has been the most difficult challange I've had lately.
这个答案有帮助吗?
Hi, I had the same problem with my MFC-J5625DW and a previous printer MFC-J5910DW, with both these printing up to A3. I don't know why, but both suddenly stopped printing from my MacBook Pro, but would print from my Windows 10.
I then noticed that when trying to print from the Mac, the small screen on the printer was indicating paper feed mismatch at the rear sheet feeder and not the inbuilt tray.
This is where I feed A3 paper which led me to check the printer default paper size and found it to be set at A3. After changing it back to A4 and testing, it worked fine.
Although the problem was solved, I still don't know why the printer settings changed in the first place.
Hope that helps.
这个答案有帮助吗?
When your brother printer won’t print black ink, it shows the error related to the computer or network. here in this article, i am sharing the steps to fix the problem.
So these are the steps to fix the no black ink issue on brother printer.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 43
总计 2,246
