跳转到主内容
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Why The android keeps turning off and on trying to optimizing?
Since 11:30 pm the cell phone shut down and all of the sudden started to optimize on his own. 1 or 2 out of 55 and the phone shuts down. I have removed the chip and the sd card. I have also removed the battery. Still doing the same thing. How can I stop the cell phone from doing that??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It sounds like you've already tried a soft reset. I'd say try and back up the data and then go for a hard reset (video if you prefer that way). This will wipe your phone!
Since it seems to be a software issue, that should fix it.
Good luck!
这个答案有帮助吗?
得分 3
5条评论:
@alphapeaches - Glad to see your involvement here!
Polyphasic sleep cycles are difficult to maintain. I was doing a lot of inter-contental travel in a previous job and gave it a try so I wouldn't have as bad fatigue jumping timezones. Sadly it didn't work for me.
完成的
Thank you so much! Been up all night trying to figure it out!! Got it fix!! Thank you!
完成的
After pressing the ON and UP VOLUME and erase all data, it seems that it was going to work, but it didn't. It kept optimizing the apps and never went on. I call the company and they told me that the cell phone was defective and I should get a replacement. Lets see how that works!
完成的
Sorry to hear it didn't work out after all. Is the company going to process it as a return/replacement or are you on your own as far as getting the replacement?
完成的
Yes. I went to the store where I originally purchased the phone and they are sending me from the protection plan a free shipping label so I can return the item. Once they receive it, I will be getting a full refund. Thank you thought!! I learn something new on the process. ;-)
完成的
添加一条评论
Hard resets don’t work any better than soft ones!!!
Phone keeps turning on/off, and battery can’t be removed, either/phone is fully charged.
Every answer on the net to solve,..FAILS!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Johanna Rivera 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 4,874
