跳转到主内容
The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
48 个问题 查看全部
Screen hinge isn’t closing all the way
When I close the laptop, the bottom right side usually tends to stay slightly open. This isn’t a huge deal, but it looks aesthetically awful. I own the 13 inch gunmetal model just in case anyone was curious.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Hi, i have a razer blade 15 and i have the same problem… the lid stays open. won’t close all he way
完成的
same when i close it it pops back up which model do u have i have the base model and did u find a solution?
完成的
Having the exact same problem on my RB15 Base model. Any solutions?
完成的
I think the lid is being held by magnets. It must be a problem with the magnets because the frame and the lid are perfectly fine
完成的
添加一条评论
1个答案
Have you tried opening up the bottom case to see if there are any screws for the screen hinge you can tighten up?
这个答案有帮助吗?
得分 0
2条评论:
Would I have to open the entire bottom? If so no, I haven’t
完成的
I have this same problem on my stealth. It doesn’t close all the way on the left side. I heard it might b the battery but my laptop looks completely normal by the trackpad and the bottom of the laptop. Maybe it’s a magnet that’s not holding it in place. Let me know if anyone has found this fix
完成的
添加一条评论
添加你的答案
AvgJoe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 2,759
