跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Why does my graphing screen keep saying "error: invalid dimension"?
I drew a circle one time, after that my graphing screen doesn't work anymore. I rely on the graphing screen a lot to check my work so if it doesn't work it's a problem for me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
for me is the same when I tried to graph an histogram, it says invalid dimension error and below 1Quit. How can I solve this?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Clara,
The ERR:INVALID DIMENSION error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff.
You specified a list dimension as something other than an integer between 1 and 999.
You specified a matrix dimension as something other than an integer between 1 and 99.
You attempted to invert a matrix that is not square.
这个答案有帮助吗?
得分 6
添加一条评论
添加你的答案
Clara Chen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 76
总计 34,623
