跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Ultra sensitive touch screen
All of a sudden the touch screen on my IPhone 6plus has become super sensitive. If I hover my finger over the screen it will select items under my finger and sometimes it seems to get stuck and keeps selecting things even if I set the phone down. What I am curious about is if any of the experts think this is a logic board issue or a screen digitizer issue?
To share all history of this phone it was briefly dunked in the ocean then shut off for 2 weeks and has worked for 4 months after that before this problem occurred. I guess it could be corrosion??
Thank you for opinions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The ocean!?! Wow, that salty water wreaks havoc on the logic board. It's amazing it works at all. Now, this might still be just a screen issue and that is certainly the easiest thing to try. When you open up the phone, you will see pretty quickly if the corrosion is minor or not.
My general recommendation is that water damage has to be addressed first. However, you may just be lucky enough that there was no real damage to the logic board and only the screen is at issue. Still, you need to think this through before investing on a new screen for a phone with water damage history and a device that is prone to Touch Disease.
这个答案有帮助吗?
得分 2
2条评论:
I have had the phone open and did not see any noticeable corrosion. Most of the solder looked pretty clean and overall the electronics etc looked pretty normal. I agree with your thought process though and if I knew it was only the screen I would probably pay the $100 for new screen but it is a water damaged phone:)
完成的
A replacement screen is relatively cheap. If you had access to one, certainly worth a try to see if it solves the problem.
完成的
添加一条评论
添加你的答案
Ajay Lamb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,611
