跳转到主内容
This printer is similar to the C4780. It lacks the (sometimes failure prone) wireless hardware and can only be hardwired for networked printing.
Why won't it print
Why isn't my HP Photosmart C4740 (Printer, Scanner & Copier) not printing?
It has a new black cartridge and half full color cartridge. The 1st print came out light blue/grey even though I chose black print. Now it acts like it's printing but paper comes out blank.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Take the cartridges out & clean the contacts with Q tips. Have your Q tip damp but not over-soaked with water. Then dry the cartridges with the dry end of a Q tip and then with a soft cloth. I used tap water, and after drying went over with a hair dryer just to make sure. It worked.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Carefully clean the tank inkjets using a soft cloth and isopropyl alcohol. Often the jets can get clogged if left in. If you don't print that much store the cartridges in the cases provided.
If that fails you'll likely need new cartridges.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tracy Klein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 400
