跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s screen goes off one time during boot
Hello, I replaced the screen on an iPhone 6s with an original (refurbished) replacement part. Since the repair, everytime I boot the phone, after a few seconds the screen goes black, then the apple logo appears again and it boots normally and works perfect most time, sometimes the touch isn't working, then I have to lock and unlock the phone and everything works fine. What could the issue be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Is the phone on iOS 11?
There are lot's of folks complaining about strange issues with the iPhone 6S and iSO 11. The worst case is when Touch fails completely. I wrote up an article on this; you can go to my profile for a link if your curious. Seeing as how your replacement screen is a refurbished original, it should have a proper Touch controller on the flex. That said, I would try another screen to see if the issue persists.
这个答案有帮助吗?
得分 3
2条评论:
Yes, it's running on 11.0.2.
I got it from a customer, who had it repaired at another phone repair store which uses aftermarket screens and the touch wasn't working at all. I replaced the screen with an original refurbished (it's 100% original lcd) screen and the touch is working again, but as said, the phone reboots once at start and sometimes the touch doesn't work until turning the screen off and on.
完成的
I tried many different screens (also an 100% original one from a new phone), disconnect all possible components which could cause the fail but still, the screen goes black once during boot and the touch only works after locking and unlocking the phone...
完成的
添加一条评论
In iOS11, it is normal for it to blank for a second during boot, it happens on every iOS 11 phone I've seen including my own phone (all original and unopened).
Make sure you have upgraded to iOS 11.0.3, as it specifically says in the notes that Apple fixed an issue where the 6S would freeze when not serviced with genuine Apple parts.
https://9to5mac.com/2017/10/11/ios-11-0-...
这个答案有帮助吗?
得分 0
1条评论:
Already noticed that, as I just had an iPhone 7 here for repair. After a downgrade to iOS 10.3.3 the screen works perfectly directly after boot, I will try flashing iOS 11.0.3 to see if it will also work...
完成的
添加一条评论
添加你的答案
ppalfinger 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 75
