跳转到主内容
加入维修社区 - 创建账户
RAM and SSD upgrade
Hi guys,
I want to change the RAM and the HDD of my Asus system, because is very slow.
What is the maximum amount of RAM that I can install in this model?
It's an i5 6198DU processor with an standard of 4 GB of RAM. I want to chage the HDD to an SSD too, can I do it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Your systems specs: ASUS VivoBook Max X541UV
And users manual: ASUS X541UV Manual
完成的
添加一条评论
2个答案
最有帮助的答案
Its a bit of work to get to the single SO-DIMM socket on the backside of the logic board to add in either a 4 or 8 GB module. As you have only 4 GB system you would either get a total of 8 or 12 GB respectfully.
Here is a YouTube Vid which is in Indian or Pakistani (sorry): Asus X541U Notebook RAM Upgrade it will give you an idea whats involved.
In addition you can see in the vid the 2.5" HDD in the far right corner. which you can replace more easily to a SSD. But before you do anything you want to first make a good backup just to make sure your stuff is safe. I would get this: Startech 2.5" SATA to USB adapter and a good cloning app to clone the HD to the SSD before swapping it out.
这个答案有帮助吗?
得分 2
添加一条评论
I want to chage the HDD to an M.2 too, can I do it?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alvik Feriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 11,821
