跳转到主内容
加入维修社区 - 创建账户
Water damaged, can't turn on after cleaning
Hi there,
My MacBook Pro was damage by the water (seriously damaged by flood), as I only realize when get home (may have been damage for couple hours).
Symptoms:
  • Can't turn on
  • No light on MagSafe LED
  • Batt LED will light up when charger is PLUGGED IN and battery check button pressed
What have been done so far: Whole board was taken out and cleaned
Before clean:
After clean:
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you tell us which model you have.
完成的
Not sure the exact model, but I saw once it was "MacBook Pro 13" 2010 Mid"
完成的
添加一条评论
1个答案
已选择的解决方案
Sadly, I think you'll need at least a new logic board. You might find looking for a used MacBook Pro as a cheaper option here and transfer your drive or files to it. As we don't know what else is damaged here.
It might be wise to first see if you can recover your data which is on the drive by seeing if a second Mac can access the files using an adapter like this: Startech 2.5" SATA to USB adapter
这个答案有帮助吗?
得分 1
1条评论:
Yes, I'm searching the used logic board as like you said just afraid it wasn't only the board was affected, thanks Dan!
完成的
添加一条评论
添加你的答案
Gaston 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 121
