跳转到主内容
加入维修社区 - 创建账户
Repair guides for Android cell phones manufactured by ALCATEL.
I can't download or update apps
I have a alcatel onetouch and i can't download or update apps in my google play store error 492 keeps popping up i really need help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
14条评论
What do I do if I don't have manage app
完成的
Hi @sabrinap83 ,
What is the make and model number of your phone?
完成的
I have a alcatel onetouch and i can't download Google Sheets or You Tube or even Update my google play store error 504 keeps popping up i really need help
完成的
Hi @casfa ,
Can you access the internet OK from a browser on your phone?
Have you tried turning Mobile data setting off then back on again and then trying to connect?
Not sure of your model but check in Apps > Settings > More > Mobile Networks > Data Connection > select OFF, the select ON
完成的
@jayeff ALCATEL ONETOUCH M/NA851L
完成的
显示更多的9条评论
添加一条评论
2个答案
已选择的解决方案
Hi @megan1990
Try clearing the Google Play Store Cache.
Go to Settings > Manage Apps > Swipe to "All" scroll down to Google Play store > Clear Cache & Data.
Restart phone and then try to download / update an app
这个答案有帮助吗?
得分 4
3条评论:
I still get this message: error retrieving information from server. DF-CHARTA-01
完成的
I am also having the same problem with my phone
完成的
It is still slowly downloading, and it has been almost an hour.
完成的
添加一条评论
Im searching for this error code and i manage to fix this issue not only clearing the google play store services cache or application cache.
in this website i found Solution No.2 https://www.errorsolutions.tech/error/go... since i do have SD card so i follow this steps.
if you still getting error when you trying to update your app or installing some app try this Additional steps to be done is to uninstall the updates on google play then update again..some of this basic troubleshooting will sort out the problem of course before you did this you need to have a strong connection.
这个答案有帮助吗?
得分 0
5条评论:
Can't update my Alcatel U5 firmware. Always get an error.
完成的
Hi, can someone help I have a Alcatel Android phone 7.1.1 it won't download apps or let me send text messages. I've researched but all I get is something I have to download! Which of course I can download
完成的
got a pixi4 alcatel phone wanted to download a app it downloads but cant open it
完成的
Any other app from where we can run our alcatel onetouch wrist watch
完成的
My playstore is not showing onetouch move app. Have fixed all other issues but again same situation.
完成的
添加一条评论
添加你的答案
megan johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 32,735
