跳转到主内容
发售于2014年春季 的一加 一拥有着5.5英寸的显示屏 运行着基于Android的CyanogenMod 12S操作系统。
110 个问题 查看全部
Installed a replacement screen - Vertical flickering issue
See this video: https://streamable.com/ktkw1
This only happens when the screen is turned on, either when the phone is booted up or awaken from sleep. This issue happens for a few mins then it goes away. The screen looks fine afterwards.
Touchscreen functionality is OK.
I would like to know if this is a defect in the replacement screen or something I messed up during installation i.e. connection etc?
Can someone also explain what is causing this issue? And why does it go away after a few minutes?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's hard to pinpoint the exact reason for this issue, but the problem may arise because of poor connectivity to the phone's "motherboard" or chip, from pressure on a portion of the LCD that was created during reassembly, or simply environmental factors like heat or cold air. I would recommend reassembling the device. If the condition continues it may be safe to look for a replacement LCD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muhammad Sarwar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 222
