跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
369 个问题 查看全部
Can you reassemble a zif connector?
One of the zif-connectors (actually the one for the bottom display), the handle jumped out. I was not able to reassemble both parts, so the question, can this be repaired? Is there a trick in reassembling both parts?
Or if it is gone, where to buy a new one and how to swap?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
i have looked and if you read the most helpful answer in this post below hopefully it can help you.
ZIF connector is broken, is there a way to replace it?
这个答案有帮助吗?
得分 1
添加一条评论
If it leapt out of the socket without you doing much of anything, it probably isn’t damaged and can be reinserted … very … carefully.
I was able to get mine back onto its hinge by carefully inserting it horizontally and working the metal tabs (the thick ones on the ends, not the delicate pins) until it snapped into place. Study the mechanism very carefully and compare to other ZIF sockets on the board to get a sense of how high the tab should be when in its horizontal position. That’s how high you should insert it—you are aiming for the ‘closed’ position of the socket. Be very gentle and don’t force anything.
这个答案有帮助吗?
得分 1
1条评论:
thats what happened to me... it just popped out and i cant get white plastic back in...
完成的
添加一条评论
Can someone help me find the short connector out of the 2 that are on the bottom side of a 3ds xl motherboard? the one for 3ds alone, is not compatible with 3ds xl. Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Klaus Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 47
总计 3,388
