跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 8 lcd flex compatible with iPhone 7?
Hi, I have a question: Is the lcd flex cable from the iPhone 7 compatible with the iPhone 8?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
7个答案
已选择的解决方案
I tested is working perfectly!!
这个答案有帮助吗?
得分 2
3条评论:
I tested it working perfectly!!
完成的
It really works?
完成的
I had my iphone 7 screen broken then my sister had a broken iphone 8. Can i use the iphone 8 screen on iphone 7?pls i need help thanks
完成的
添加一条评论
最有帮助的答案
From what I've been able to tell looking at the connectors the LCD may be compatible but the digitizer is not.
这个答案有帮助吗?
得分 8
1条评论:
I just installed a 7 screen on an 8, The larger connector fit, small one not. Using only the larger connector the 8 has full display functionality. LCD and Digitizer both are working well.
完成的
添加一条评论
iPhone 8 LCD SCREEN install in iPhone 7, the phone works but touch function is not working. So it is not compatible.
这个答案有帮助吗?
得分 8
添加一条评论
If you want to break your phone, put a 7 screen on an 8.
这个答案有帮助吗?
得分 4
8条评论:
How does it break it? What damage are you saying it causes?
完成的
It may damage the 3D touch connector, the iPhone 7 3D touch connector is bigger than iPhone 8
完成的
any solution for this?
we test a good ip7 screen on ip8 suddenly touch screen not working
even we install back ip8 original lcd screen
完成的
You have to replace a new LCD flex cable connector on the iPhone 8 motherboard. More details you can read here:https://www.etradesupply.com/blog/how-to...
完成的
Thats True , i did , now my iphone 8 plus , touching not working .
完成的
显示更多的3条评论
添加一条评论
This thread is really worrying, stick to the same model screen, it is really better to play it safe then to make a $400+ phone damaged.
Unless you don’t mind taking a risk of damaging the phone as said by others the screen connector on the board will get damaged due to different size of ribbon cable plugs on the screen itself..
这个答案有帮助吗?
得分 1
添加一条评论
Why would anyone care so much as to why doing this would cause such critical issues. There is one thing about these two models screens that have little to no difference in them, therefore 100% optional on which to buy for your phone model and that is the price. I could see such questions being asked if the iphone 8 screen was significantly higher than the 7. Or vise versa. But they are identical in price so, why would you ever give a $@$* if the connectors were the same? Just buy the appropriate screen and it will never matter if they are cross compatible. I get that maybe you didn't have the correct one. But get amazon then and tomorrow you'll have the correct screen for your model.
这个答案有帮助吗?
得分 0
添加一条评论
I didn’t realize the screen was the wrong one. But the iPhone 8 has LCD and Digitizer working with only one connector of an iPhone 7 screen. The larger connector of 7 screen fit the 8 device, but the smaller one wouldn’t. With only one connector the 8 device with 7 screen has full display functionality.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Begara 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 31
总计 8,042
