跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
MacBook 2016 touchbar after only 1 week use won’t turn on
I just broke my MacBook Pro!
I had fully charged it, then travel with plane when I arrived, it didn’t work. I tried resetting SMC, I tried holding the power button in different scenario, I even opened her up disconnected the battery and no luck, I was wondering where are the power pads to jump start the mac?
And what do you guys think happened ?
I did set an appointment but it’s in 10 days and I really need my computer!
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Bummer, Sorry to hear about your computer. Did you spill anything on it during the plane ride?
完成的
添加一条评论
2个答案
Unfortunately, the 2016 and 2017 MacBook Pros no longer have power on pads.
Update (10/06/2017)
I would try booting it in minimum configuration. Disconnect everything from the logic board, and then plug it into power. The 2016 and 2017s now auto boot when plugged into power. If it is booting in minimum configuration, then you can add components to see what is causing the problem. If it still does not boot the logic board will need replaced.
这个答案有帮助吗?
得分 0
1条评论:
whether the fan is removed too
完成的
添加一条评论
i see, any suggestion ? i had this problem with macbook 2011-2013 and when i disconnected battery and reconnected it it was fixed but in this one nothing helps
这个答案有帮助吗?
得分 0
1条评论:
See revision to my previous comment.
完成的
添加一条评论
添加你的答案
mehrad raissi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,089
