跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
How to repair or replace the micro usb port
Ok so my Samsung Galaxy SIII stoped charging, I can get it to charge for a split second but the battery was fully drained so I cant start my phone up yet. it is quite hard to maneuver the micro usb to a valid conection and i am sure its bent beyond repair. I tried desoldering the micro usb but my soldering iron doesn't get hot enough (cheap hobby iron with no temp. control) how do I fix the port so I can use my phone again?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
well i believe you already started doing it yourself, if the solder contacts on the connector look like it has a solid connection to the circuit board then that shouldn't be the issue, and you should look at the contacts that the cable connects to, to see if anything in there looks out of place, if not then try cleaning the connections with isopropyl alcohol. You can use water but that will cause corrosion creating problems in the future if you can get to them, if cleaning doesn't work then i'm afraid that you will have to get a higher voltage or multi-voltage soldering iron and buy a replacement micro usb port .
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Todd Riley (Nathanyal100) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 983
