跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why is my device stuck on searching even without sim card
I have an iPhone 5s that worked perfectly fine (sim card and everything) until i reset it. Unfortunately afterwards the top left carrier text just said "searching..." eternally. I thought it was a problem with my sim card, but it does this indefinitely even without a sim card in the phone. I can still use the phone for the most part, but i cant use it as a phone. The phone also no longer has an imei number, but i have a screenshot of the old one.
The phone also freezes for a few seconds every 10 seconds. I looked at the real time system log and basically it tries to launch CommCenter every 10 seconds and it crashes. Im assuming this has something to do with the cellular signal.
I've tried disconnecting the battery, resetting the date, freezing the phone, and force rebooting. Ive looked around for a solution. Restoring the phone doesn't do anything as far as i know. Several people say that the baseband needs to be replaced, but i have no idea how to do that. I really dont want to go through apple
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Baseband chip issue. At this point I would give up on the phone because this kind of repair is very hard, and expensive to do.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Trans1000 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 485
