跳转到主内容
The Lenovo IdeaPad 300-17ISK is a 17-inch laptop which was released in October 2016. The Model number is 80QH008MUS.
13 个问题 查看全部
Why does my laptop keep turning off and on?
Hi, this morning I tried using my laptop but for some reason it would go pass the logo screen and then it goes to the Novo button menu screen but when I try to click on an option it turns off then back on and off repeatedly, I tried holding down the power button but it shuts off and on before I can do that, what do you think the problem might be? Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I've had a couple of these come into my shop with board issues. They are always miserable hard to diagnose problems and I've yet to fix one yet. This sounds like how they start to fail. Then it will not power on and the keyboard light will flash every 5 seconds. I have no idea what is causing this on them. May be a RTC issue (The thing that puts all the "thinking" components on a timer so they can all talk to each other efficiently) . But as of right now the only solution i've found is a new motherboard.
这个答案有帮助吗?
得分 1
添加一条评论
If your laptop is showing no signs of life and refuses to turn on, use this Lenovo IdeaPad U530 Touch Does Not Turn On problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TeenaL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,443
