跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
The initial phone opening technique is not working, adhesive too stron
I am having trouble using the ifixit kit to successfully open the GS6. The adhesive holding the rear glass is not loosening up for me to be able to remove it using the provided suction cup. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
are you using a hot air source like a hairdryer etc to heat it
完成的
Thanks, will definitely try that!
完成的
Use a playing card.. Get the glass up enough you can get a playing card underneath and use it to break the bond between the glass and glue
完成的
添加一条评论
3个答案
已选择的解决方案
As Daniel has suggested, I would use a Blow Dryer or a heat gun to heat the back. Heat it up just to the point of it being uncomfortably warm to the touch but not so hot that it burns you.
这个答案有帮助吗?
得分 1
添加一条评论
Please if you're unsure of doing it with a hair dryer or heat gun DON'T DO IT! iFixit has an awesome tool that works great for this iOpener
iOpener图片
产品
iOpener
$19.99
这个答案有帮助吗?
得分 1
添加一条评论
You need heat. Without heat you will not get it off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bert486 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 179
