The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
darlenebarber54 @darlenebarber54
声誉积分: 1
发帖于: 2017年9月26日
will not print from computer
这是一个好问题吗?
5条评论:
Hi,
Has it worked OK before when connected to the computer?
Does it work OK if you try to copy or scan a document using the printer's control panel?
If it works when using the printer's control panel, what make and model of computer is it connected to and what OS is installed in the computer?
由 jayeff 完成的 2017年9月26日
Printerhead? what do you mean? or are you trying only to print from your pc?
由 jbermudez27 完成的 2017年9月26日
Yes. It is not printing from computer or copy or fax
由 lorenzo.walker 完成的 2018年1月17日
Hello jayeff,
It is not printing from computer, or fax, or copy. I have replaced all ink cartridges in printer
Hi lorenzo.walker,
Have you tried a 'Clean Printhead"operation from either the printer's control panel or the HP printer software in the computer?
On the printer press the Right Arrow > Setup > Tools > Clean Printhead.
Do it 2-4 times to see if it starts to print.
由 jayeff 完成的 2018年1月17日
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 61
Hi,
由 jayeff 完成的
由 jbermudez27 完成的
Hello jayeff,
Hi lorenzo.walker,
由 jayeff 完成的
