跳转到主内容
The DigiLand DL701Q is a 8GB tablet with a quad core 1.3Ghz Mediatek processor.
How do I get past a forgotten password
My son put a password on his tablet and can't remember what it is I've factory reset it using the tiny pin hole button in the back but no luck it's still locked with his password. Any ideas I'd love to have this devise working again
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
4条评论
Yay! Thank you very much it worked!
完成的
Congrats!...good job:)
完成的
Someone please help a dumbass I have a digilandDL808w lost password when I enter wrong password it says to use a flash drive but what do I do after insert flashdrive?
完成的
Nothing works anymore, but will make an attractive paperweight, or improvisational projectile in case of emergency.
完成的
添加一条评论
2个答案
已选择的解决方案
Turn it off. Then hold volume button and power button at same time until it begins to boot. Use arrow keys to scroll to clear cache, then power button to select it. After it clears, scroll to factory reset and use power button to select it. It should reset. Let me know if you have any problems or questions
这个答案有帮助吗?
得分 5
7条评论:
If it comes up in korean, the sixth option is the factory reset.
完成的
I pressed the 6th option but it just brought me to a new page with korean writing.
完成的
i do not remember my pass word
完成的
Today I got this tablet but it don't work no more because I don't know the password I didn't make a password in my brother that make a password either so I don't know about the path I don't know the password
完成的
My Digiland brings a different menu then stated. Recovery Mode, Fastboot Mode, Normal Mode. I selected Recovery brings me to a Android with a triangle. error message no command. How do I proceed?
完成的
显示更多的2条评论
添加一条评论
Is that tablet android based??? I think you can restore de default settings of android, but you will lose any information on it..
这个答案有帮助吗?
得分 2
2条评论:
How do I do that? I cannot get past the lock screen.
完成的
My digital tablet forgot password.trying to factory reset.power keeps coming on.please help..
完成的
添加一条评论
添加你的答案
Raina oneil 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 47
总计 7,091
