跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No automatic Brightness adjustment after screen replacement
I changed my screen two days ago because of a cracked screen. I already bought not the cheapest replacement kit I could find.
Installing the new screen went great. But I noticed that the screen brightness wouldn't adjust automatically after that. I tried everything I could find online, from re-calibrating the brightness sensor, to turn the feature off, and soft reset the phone. I did not try to reset all my settings because that's what I'd like to keep.
Does anyone has a new idea?
I don't mind opening the phone up again to solve it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Your ambient light sensor is either bad or wasn't reinstalled correctly. Step 25 in this guide: iPhone 6 LCD屏幕面板的更换
这个答案有帮助吗?
得分 2
4条评论:
I bought an completely new display unit. Does it mean the display does not have a brightness sensor built in? And I have to replace it with the old one that worked in my broken display?
完成的
I have no way of knowing if your display has a brightness sensor built in. Where did you buy the display from? Is everything else (earpiece speaker, camera, etc) there? The brightness sensor is part of the camera flex cable.
完成的
In fact, it was the brightness sensor built into the new display. I changed the camera flex cable with the original one and it works perfectly fine now.
Thanks a lot.
完成的
i need brightness in screen
完成的
添加一条评论
It happens when your phone has Amoled or Oled display but the replacement screen you brought is probably a Chinese LCD . Amoled phones has different way to control brightness by varying brighness of each pixel and it cant support backlit control for LCD screens.
这个答案有帮助吗?
得分 0
添加一条评论
Hi! I bought a new screen for my iPhone 6S plus from ifixit and followed your suggestions by repleaceing the new brightness sensor with the old one , but it doesn’t work anyway…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin K 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 8,644
