跳转到主内容
Model A1842. Released September 2017, the revision to Apple's 4th generation set-top-box featuring an A10X Fusion processor and 3 GB of RAM.
14 个问题 查看全部
Does the Apple TV 4K have a fan on the bottom? Just curious.
It looks like (from pictures) that the Apple TV 4K has a vent on the bottom. I’m wondering if it has an active cooling solution (i.e. with a fan) or is just passive cooling (without a fan).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Really want to see the teardown for this one! A10X with active cooling might be a screamer.
完成的
添加一条评论
1个答案
已选择的解决方案
Until someone does a teardown we won't know for sure.
I suspect there is a fan and a heat pipe system. Why do I think that? If you review the images you'll see there is no other opening for the air to enter or exit (chimney effect) for a passive system. The air must be coming in on one slot set and exiting on the other side on the bottom being moved by a fan.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Reid Fleishman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 1,792
