跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Home button: erratic behavior
Dear iFixit,
I searched the old posts but have not found a solution.
The home button on my iPhone 3G after it went from OS 2.1 to 3 (and now at 4.2) has some very strange behavior.
Every now and then smashing it works perfectly, while other times you have to press it very very strong to be able to operate. I do not think a hardware problem (because as I said sometimes it works fine) but something of a 3d generation, the problem is more noticeable when you use applications 'of a certain weight' and I can return on home screen only if I press very strong (so strong that the LCD screen floats...)
Do you have any suggestions to help me? I'm going crazy and use it so it's very frustrating.
I just did a restore when I switched from OS 3.1 to OS 4.2.
Thanks.
Vincenzo
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
colorsthink,
Open it per the guide and check the gold contacts that come from the home button flex ribbon cable. I have one on the bench right now that had this same issue and what I found was one of the prongs on the gold spring contacts is hanging on by a thread. In fact I believe if I put it back together it would fall off. The switch itself is relatively inexpensive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
colorsthink 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,196
