跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
both camera's + flashlight not working.
hey people i got an iphone SE with both camera's and flashlight not working. the board looks perfect. the screen has been replaced some time but the customer says the camera's stopped working after a drop. any advice for this repair? i know about the camera jumper on the 6 an 6s.. but i dont know realy where to begin on this one..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The cameras and flash are on separate flexes. The only common denominator between those three is the CPU. Let's put that aside for now as it seems unlikely to be the problem.
I would check the voltage on the PP2V85_CAM_AVDD rail. It drives both cameras and the RCAM also sends an enable signal to the Strobe circuit (RCAM_TO_LEDDRV_STROBE_EN). In theory, if 2V85 is bad, then both cameras stop working and the enable signal to the Flash is missing, hence no flashlight.
If you don't have the tools or experience to troubleshoot at the board level, I suggest you seek out an experienced micro-solderer. If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
这个答案有帮助吗?
得分 2
1条评论:
Could you let me know if 2V85 is "BAV23S Dual high-voltage switching diodes"?
If not then what kind is it and where could I buy that one?
Thank you very much in advance.
完成的
添加一条评论
添加你的答案
thieske 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,658
