跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
iPhone 7 plus not working
Hi Guys,
I just updated my Iphone 7 plus to the new ios 11, after the update phone isnt responding as it should, touchscreen is taking years in responding to swipes, same for the apps take !&&* lot of a time in opening up, Sound isnt working either not in calls, ringtones, games or music etc.
I reverted back to IOS 10.3 and its all fine but not on ios 11
I had my phone's screen repaired (aftermarket) because of the damage and I read somewhere its because of that the new ios isnt working
I will be very glad for any help
plus I live in Pakistan and to my knowledge there is no apple genius bar here.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Has the phone been damaged before? Not by ios.
完成的
Yes as I said I had its screen repaired because of the water damage the board of product also got short circuit because of that so they replaced both of them
完成的
添加一条评论
2个答案
已选择的解决方案
There are widespread reports of aftermarket screens not working with iOS 11. The only thing to do right now is to stay on iOS 10 (or go back while you still can) until this problem is solved by Apple, assuming they want to resolve it, or get an OEM quality screen.
这个答案有帮助吗?
得分 2
3条评论:
I already paid 1800$ for this screen thinking its OEM quality, Are there any chances that Apple would fix it?
完成的
Is that USD (US dollars)? That seems wrong on so many levels. You could look at this (iPhone 7 Plus Screen). "Choice" screens at iFixit are OEM level quality.
完成的
@omer257 There's a change, but its highly unlikely. Reverting to 10.3.3 is the easiest solution to get your phone back in usable condition. We've seen things like this in the past, and with enough uproar they usually get handled in a timely fashion by Apple. Fingers crossed.
完成的
添加一条评论
iOS 11.0.3 update is supposed to have corrected some problems with iOS 11 running on an iPhone with replacement screen. It wasn't available at the time of your post. Wondering if you are up to date and if you are still having the same issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Omer Farooq 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 498
