跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Siri can't hear me nor does voice dictation work
My microphone works for phone calls and for recording, but Siri can't hear me (total flat line) nor can I dictate into any app. I've checked all the settings. Rebooted, etc. all the usual things. However, Siri and voice dictation work fine through my headphone jack, just not through the microphone. Is this a hardware problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I should add that I just swapped in a different logic board. Could I have missed a connection?
完成的
添加一条评论
3个答案
已选择的解决方案
There are 3 microphones in the iPhone.
https://support.apple.com/en-us/HT203792
  • The bottom microphone is for Voice Memo and phone calls. The other microphones serve as error cancellation
  • The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera (FCAM). The top back microphone serves as error cancellation
  • The (top) back microphone is used for videos with the rear camera (RCAM). The top front microphone serves as error cancellation
I would test the microphones with the appropriate apps to determine if the problem is specific to a microphone (change the appropriate flex) or multiple microphones which could indicate a logic board problem.
这个答案有帮助吗?
得分 5
2条评论:
I have the same problem. How do I check the mics?
完成的
How do I check the mics please.. what app
完成的
添加一条评论
use a toothbrush, and lightly brush the mic holes and you'll see that the rainbow wave animation moves for both top and bottom mics. Siri has stopped on two iphone X's after jailbreaking. Also a samsung watch wont connect either but it will after a clean reset.
这个答案有帮助吗?
得分 1
添加一条评论
Same issue here microphone working fine on other apps not problem, Siri works with side bar and hears me fine. Only issue I can activate “hey Siri” feature. Was working before update 14.2 on iPhone XR
这个答案有帮助吗?
得分 1
1条评论:
Did you find a fix?? I have the same problem.
完成的
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 26,289
