跳转到主内容
The first-generation Ford Focus was manufactured in Europe from 1998-2004 and in North American from 1999 to 2007.
33 个问题 查看全部
2003 Ford Focus no acceleration
My missus's trusty 03 Focus has developed a rather bad problem, she was coming back from the shops this morning and it started to die on her, she managed to get it back home and i took it for a drive, It idles fine and revs in neutral no problem and when initially accelerating off it seems OK but after driving for half a k or so when trying to accelerate it just dies, still idles fine, doesn't cut out at all but just no acceleration, I could sort of idle home but give it any revs it just dies back, not cutting out just very weak acceleration, Also I'm pretty sure i can hear some pinking that was never there before.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
6条评论
I have the same EXACT problem......did you solve it? Fuel pump?
完成的
Please come back and tell us how you solved it!?
完成的
Same problem with my 02 ford focus 100k mils and I took it to be read with the OBDll no codes.
完成的
Blocked Catalytic convertor.
完成的
Guys the problem is a blocked catalytic converter or partial blockage of your exhaust system. How I found out mine is by taking one of the o2 sensors out and starting it for ONLY a little while because you can burn things like wires ect. But it allowed my 2.3l focus to rev all the way and no more bucking while driving and it ran like a little rally car again! So I will try to unclog the debris that is in the exhaust by debris I mean the insides of my cat that rattled apart after awhile. Good luck.
完成的
显示更多的1条评论
添加一条评论
4个答案
已选择的解决方案
@edwarrd This is a case of fuel starvation . There are many possible reasons for the fuel starvation . The best thing to do is check for engine codes ,OBDII codes . The most probable issue would be fuel lines leaking of a plugged fuel filter. If this brings no joy then move on the sensors . Clean the Map sensor and clean the throttle body . Check your o2 sensors. You can also check for back pressure on the fuel tank . test this buy running the car without the fuel cap . there could also be a plugged Catalytic convertor. Is the car overheating when this is happening ? If so it could be a timing issue . it could be a bad timing belt or chain and the pinging your hearing is bad timing. The best thing to do is get the codes read . When you do let us know your codes and we can help further. Hope this helps
这个答案有帮助吗?
得分 7
1条评论:
I have a2003 Ford focus it well idle fine but put it gear to drive it has know acceleration lit off it well run but we'll die iv put new coil new plugs wires new fuel pump new filter new pressure sensor can you help it has the code p0191
完成的
添加一条评论
Sounds to me like the coil pack.. 30 quid second hand, 4 screws, 4 spark leads and a sensor wire to be swaped over..back on the road.
这个答案有帮助吗?
得分 1
1条评论:
My car keeps surging .. if I have the air on and the lights my lights flicker on and off .. if I turn on my fog lights or the dome light it surges on and off .. help
完成的
添加一条评论
I concur. New ignition coil and HC leads solved this issue on my 2005 MK1 1.6
这个答案有帮助吗?
得分 0
1条评论:
Get a new version updated OEM coil pack. The old ones are designed to fail. One huge problem solved. Trust me. Been there 3 OEM coil packs. 10 years one updated coil pack later perfection.
完成的
添加一条评论
2003 Ford Focus 2.3 When you gas it or come to a stop light and have your foot on the brake it hesitated
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ed Claydon 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 115
总计 17,578
