跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Broken screen, no wifi. How odd.
Customer's iPhone 5s was dropped, screen smashed but functional. Customer's boyfriend replaced the screen with one he bought from ebay. Upon reassembly they discovered that the touch function on the button no longer worked, and the phone was no longer able to get on wifi (Settings -> Wifi was grayed out, as was the icon in the Control Center). Following directions he found online, he reset the network settings (Settings -> General -> Reset -> Reset Network Settings). When the iPhone rebooted Settings -> Wifi was now accessible, but when he tapped on it the phone would hang; the Settings app basically crashed. After some more experimentation he reset the iPhone completely (Settings -> General -> Reset -> Erase All Content and Settings). When the phone rebooted/reset Wifi remained accessible and he can tap on it without crashing the phone, but no wifi networks show up. It just pinwheels, looking for networks, but finds nothing.
That's how the phone is now. The touch button part is probably just clumsiness; he probably damaged it when moving it from the old display to the new. But the wifi thing is a question mark to me. It's odd to me that it would behave differently during the various resets. Replace the wifi antenna?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
No this wont cause that issue on the 5s the problem here whatever screen he use from ebay overheated the board causing the Wifi chip to grey out.You can try taking the board out and use a heat gun for 10 seconds and reheat the wifi chip is the big white one and put it back together if it didn't work the chip is damaged not fixable .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 427
