跳转到主内容
加入维修社区 - 创建账户
Soldering to USB +5V
So i have that Ali express LED Lamp projector, it has in build speakers and a LCD image unit that displays in 800x600. I thought i would be nice to upgrade it with a raspberry pi 0 that i got for birthsday. Just to play around with emulators.
I want the Pi to sit inside the projector, there is even some room left for it, i would take the HDMI cable outside just like this guy did:
https://www.youtube.com/watch?v=mff-F39f...
And use the 5V pin of the USB (inside the projector) port to the PI
My simple question is:
Will the USB port from the projector still work (for USB sticks) when the raspberry is powered by it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you!
Didn't thought about the heat. And there's really not much free space left for proper ventilation with the Pi inside.
完成的
添加一条评论
1个答案
最有帮助的答案
I wouldn't use it. The RPi 0 requires a minimum of 2.0Ah. It's had to imagine that the projector outputs more than 500mah. It'd probably run, but not very well. And certainly not when a USB flash drive is in use. You should use a separate power supply.
Last thing, if the projector is even slightly hot it will probably overheat the RPi.
Hope this helps!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Prokrastinator 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 130
