跳转到主内容
Motorola smartphone released June 2016 with additional features called Moto Mods (Speakers, chargers, etc). At the time of its release, the Moto Z was the thinnest smartphone ever (5.2mm). Model numbers XT1650-01 and XT1650-03.
30 个问题 查看全部
Moto z Bluetooth can't detect devices
My Moto Z brand new doesn't seem to be able to detect any bluebooth devices. I try using NFC and it'll recognize the NFC tag but will not pair. Do I need to replace something? I can't warranty it because I bought it off someone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My moto z connects just fine to my Aukey Bluetooth speaker. I am having issue with my new Sony headphones though, it won't discover it when it is discoverer by all my other devices. Does anyone have a work around?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi!
The first step is to identify your problem.
Make sure Bluetooth connectivity is enabled in the first place by checking the Settings under Bluetooth.
Go to Device Help (it's the app with the round blue icon and a white question mark), slide left to the "Fix it" tab, scroll down to sensors, then select Bluetooth and let the test run. Keep me posted with the results.
这个答案有帮助吗?
得分 3
2条评论:
My Bluetooth is unable to find devices.
完成的
I am trying to pair a Motorola Moto Z Force with a Blinc 3.0 that is on a motorcycle helmet, but they just aren't able to see each other. I have tried everything I know to do, but I am starting to think maybe my Moto Z just can't see a device running Bluetooth 3.0? It has to be a compatibility issue, no other explanation comes to mind...
完成的
添加一条评论
添加你的答案
Ian Wong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 7,304
