跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
How do I fix the apple screen loop?
I replaced the logic board, hard drive cable, battery, and the hard drive with an SD card adapter. It restored and in disk mode was able to load music back on no problem. When I exit disk mode and try to use the iPod, it goes to the apple screen, turns off, and goes back to the apple screen, then turns off... over and over.
I don't really know what else I can replace, but figure someone here probably knows more than I do! The SD card reader is the iFlash Solo and the SD card is a 64GB card referenced as working on my model on the iFlash site.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Just check the ribbon connector to the Iflash card is connected properly and when you inserted a Sd card it should give a clicking sound.
If it still doesn’t work it could be a faulty iflash card
这个答案有帮助吗?
得分 0
1条评论:
And when you restore the ipod the ipod should itself restart and just check the hold button should be off position
完成的
添加一条评论
添加你的答案
John McPherson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 114
