跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
LCD and Screen replacement
I removed the gold strip next to the battery above the home button flex when removing the LCD digitizer after front glass removal. Can I continue with the repair or is it now repairable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You should upload a picture of it then others can help you.
完成的
添加一条评论
1个答案
已选择的解决方案
The best way to find out is to test the new screen and see if it's responsive. I'm not entirely sure if it's just a heat dissipation piece or part of the sensor for the touch screen.
I know the back of the new LCD should have the film attached as well, so I can only assume that it's a heat dissipation piece.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lainey Yancyfjgbmp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 153
