跳转到主内容
Why do my internal keyboard and track pad both become unresponsive?
This is the details on my system:
MacBook Air core i5, 1.6 GHZ 13' (early 2015) (I5 - 5250) Model: A1466 (EMC 2925)
ID: MacBook Air 7,2
Maybe last night, I spilled my system but it's only very little spilled water like one or two drops water and I wiped it as fast as I could.
Everything was fine and suddenly my trackpad and keyboard are unresponsive. And There's like some pop up message tells me that its searching for bluetooth keyboard & trackpad.
I tried to shut down by pressing the power button in about 10 sec, when I tried to open up again and press the power button nothing happens, system is now totally dead!
Both of my internal keyboard and trackpad become unresponsive, including my power button. So now I can't log in or even do anything.
So stressfull about this. Could you give me some advice?
UPDATE
Today I tried to connect the charger cable and MagSafe LED indicator shows orange and it's charging. Does that indicate that my battery is not the problem?
I do a method that I got from YouTube, I press the PB for 10 sec then I plug in my MagSafe cable in, the green LED indicator didn't show on, but when I released the power button, the green LED indicator shows up. Is this indicating that my keyboard is responding?
What happen to my Mac and What should i do? Thank You.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
So after 6 days, I just got my MacBook back to live again!
So here's the answer.
I bring my MacBook to service center in Indonesia, they checked it and then turn out that my Flex Cable 593-1604-B burnt. That's why my MacBook can't turn on normally. Then he checked the water damage, but there's no corrosion in my MacBook and Logic Board seems good. So they change the cable, it only cost around 45$, seems the cost better than to change the logic board i think.
Thank You all for the respons.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
What could have happened was the keyboard cable got disconnected or cut. A similar thing happened to my MacBook Pro. What you can do is unscrew the bottom plate, and when the computer is plugged in, create a short between these two pads.
This will basically be the same as pushing the power button. If you want to repair the keyboard and trackpad, unplug the battery and power adapter. The battery connecter is located on the far left beneath the power pads. Check the other cables next to the battery connector for breaks or if they're disconnected.
and if they are fine that must mean that the cable has been broken further along the line. To find the break you have to remove the logic board. Just Google 'how to remove logic board on macbook air 13'. Hope that fixed your problem.
这个答案有帮助吗?
得分 2
2条评论:
Be careful here! There are a few different MacBook Air's as such the Power Pads are not all at the same location.
Until we get the OP's exact model its a bit of a gamble to point to locations on the logic board to poke as it could cause damage.
But you do have the right idea on how to diagnose things.
完成的
Hi, thank you for the respons.
Please check it out. I just give some details about my MacBook.
完成的
添加一条评论
添加你的答案
Clara Angela 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 493
