跳转到主内容
加入维修社区 - 创建账户
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
My instax won't turning on and lights don't appear.
So I have my instax in 2013. And I forgot to change the batteries so it kinda melt but I clean it and battery socket all fine and no rust and so whatever. So I placed new battery and it works well. After I know it works well, I took out the batteries. So today 16 Sept 2017, I try to switch on again, but light won't appear, and it doesn't produce sounds anymore. I put brand new alkaline battery. However I noticed, my instax feel hot at right top corner. So I took the battery out and the hot cool down. Can you help me fix my instax please . Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @izzajuhari, to check more on this, you need to dismantle the camera to the internals.
here now, you need some skills to check, else if you are not confident, you can ask your electronics friends to assist you.
take caution of the film capacitor as it can contain some charge... do discharge them before any repair attempts.
with the battery on, try to identify which electronic components heat up....
would be great if you have a infrared thermometer to check on this, else by left sometimes i check with my fingers, but note, it can be very hot and cause burn.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Izzatul 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,966
