跳转到主内容
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
23 个问题 查看全部
Black print head clogged with ink.
This has been a gradual failure to print just the black. I have done 3 cleaning cycles, over multiple days, this worked a little but used quite a bit of ink. Then I used a syringe kit with cleaning fluid and paper towels under the head. Made a bit of a mess and pulled out a bunch of color ink at the same time. That did help, I got back about 90% of the print range. However it quickly failed again to 0%. All I have used in this is Brother Ink.
Can the print head removed more a through manual cleaning? What happens to the ink used in the self cleaning operation?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
How do you clean the "print head"? I can not get a full ink cartiridge to work. It says "no ink". ZBest Buy says to buy a new machine and so do my friends. Not an option. Help!
完成的
Thanks for the post. I am having the same issue and was about to begin the cleaning you did. Did about 6 cleaning cycles and emptied my Mag cartridge that was already low. eventually helped, but still not so good. Would not print with Mag empty, so I partially filled it with solution of 10% Iso alcohol and water with 1 drop of soap.... used about 5 ml injected into the cartridge .
Printer cleared the "empty" mssg and allow me to print in "gray" scale for now. Instruction on cleaning say to remove the ink first with sucking into syringe. Will remove about 10-15 ml of ink.. Let sit for 5 minutes. Then start flushing slowly with cleaning fluid. Then replace same vol of ink. Then do cleaning cycle or 2.
L
完成的
添加一条评论
1个答案
最有帮助的答案
Hi forrest laiche , normally there are several ways, some will replace the print head if it is too bad, another but not recommended is to clean with a little IPA .
the ink used for the self cleaning will be deposit into the printer waste ink pad, which is hidden inside the printer.
这个答案有帮助吗?
得分 1
1条评论:
I should be more specific. How would one go about removing the print head? And how would I clean out the printer wast ink pad? Because after all the cleaning cycles i have done it has about half a cartridge of ink in it.
完成的
添加一条评论
添加你的答案
forrest laiche 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 59
总计 6,278
