跳转到主内容
加入维修社区 - 创建账户
The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
RPM varies while driving
While driving at 60 mph the engine rpm will jump up a couple hundred rpm then drop back down. It will do that constantly. What might be causing it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hit the overdrive off button on the gear selector and drive. Does it still do it?
完成的
添加一条评论
1个答案
已选择的解决方案
It could be your IAC (Intake Air Controller) that is stuck in the open position which could explain the RPM's jumping around. Try removing it and spray cleaning it and then reinstalling. Make sure however that it is moving freely after the cleaning otherwise the issue will still be present.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,745
