It won't turn on
It won't turn on no power at all it was working but now it's not
To troubleshoot this problem :
Plug something else into the same outlet. If it doesn't work, than it's a problem with that outlet.
It could also be a problem with the power chord. Make sure it's connected correctly. If you can, try to use a different one.
Check the connectors on the power chord and the outlet on the PS4 itself for sign she of damage.
If none of these work, it's probably a problem with the power supply. These are quite common, but you're probably have to take it in to a repair place.
I personally sent mine in to TronicsFix and I would highly recommend them if you decide to send it in. If not, there are various guides in the internet to replace the power supply yourself.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 270
Power from outlet?
由 TCRS Circuit 完成的
Does it have bugs in it?
由 TronicsFix 完成的
