I can't access my files
Why can't I access my files it say something is turned off or not installed?
The only thing I can think of without seeing the device is that one of the main programs that utilizes whatever you're are attempting to open is disabled OR needs to be updated in the play store.
If you go to settings > applications> and look for the disabled and/or check for a software update, check the play store for application updates that may run the file you're attempting to open.
The only application I can think of for the S5 is either called Memo/Notes.
这个答案有帮助吗?
It works now thanks
Glad to hear it!
Thanks iowloakkalsl
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,415
7条评论
Can you be more specific about what you are trying to access
由 rohith rangaraju 完成的
If I go to settings look in storage at explore nothing that I try to open will says it's turned off or not installed
由 Bill 完成的
What's turned off or not installed? We can't see what you can, so you'll need to give us as much information as possible.
由 George A. 完成的
@pccheese you're doin great, kid. Keep goin
由 iMedic 完成的
@bmur98, do you see a "My Files" app in the phone? That can view your files and open your folders normally.
由 S W 完成的
显示更多的2条评论
