跳转到主内容
加入维修社区 - 创建账户
具有 1000 万像素、10 倍光学变焦和图像稳定系统的内置闪光灯紧凑型数码相机。拆卸需要使用特定的设备。
large size pix. megabytes instead of kilobytes . too large to email.
pictures I download to pc now are like 2000 kbs instaed of 200 kbs. what setting did i change. too large to email.
Update (09/14/2017)
Hi, I could not find any compression/recording pixels or recording pixels setting. Canon SX120. Could it be called something else? Thanks John.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @trimmerbird, I think you had set to a higher resolution, etc
else, if the picture was taken, you can use online image resize to compress your pictures.
you can try this,
1. Turn on the Canon camera by pushing the toggle or turning the wheel at the top of the camera -- depending on your model -- to the "On" position.
2. Press the "Func/Set" or "Menu" button, depending on your PowerShot series.
3. Press the labeled buttons that serve as left and right arrows or press the "Omni Selector" wheel to scroll through the settings. Select "Compression/Recording Pixels" or "Recording Pixels."
4. Press the "Func/Set," "Func" or "OK" button to save your settings.
Tips
The recommended resolution for most digital photos is M2 or M3 at a resolution of 1,024-by-768 photos for some cameras as 1,600-by-1,200 for other Canon series. With this resolution, the Canon PowerShot produces clear photos small enough for emails but detailed enough for digital documents.
For high quality, space-saving photos at any resolution, set your compression setting to "Fine."
Credit:
http://smallbusiness.chron.com/change-re...
这个答案有帮助吗?
得分 1
1条评论:
It's the same problem when scanning docs on my Epson.
由完成的 分享
添加一条评论
添加你的答案
john trimmer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 25
总计 353
