跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Phone does not turn on at all - Tried new battery and screen - U2 Chip
Hi All
Have an iPhone 6S that will not turn on at all.
Tried putting a charged battery in and a new screen still will not turn on at all.
Could it be the U2 chip? I thought even though it was faulty it would still turn on with a charged battery.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Even a defective Tristar should get to the Logo screen...usually.
Is you phone detected by iTunes if connected to a computer?
Your problem sounds more pervasive. Have you probed the circuit board, primarily PP_VCC_MAIN & PP_BATT_VCC to see if they are shorted? When "powered" by a known-good battery, do you see the proper voltage levels? This is the first thing to check, after the battery, on dead devices.
If you see shorts or no voltages, then this phone will have to be looked at by an experienced micro-solderer.
这个答案有帮助吗?
得分 3
2条评论:
Not detected by computer, have not probed the circuit board.
Are you saying to test those points with my multimeter?
Do I need to ground against a certain point on the board or just the chassis?
完成的
You need to find a ground point, chassis or otherwise. You should search for and download the schematic in order to do this properly.
完成的
添加一条评论
添加你的答案
Brick50 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 83
