跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE turning itself off on lock screen?
Phone was dropped down the toilet. I tried to fix it using the isopropyl alcohol method. All seemed fine, but then the phone turns itself off when it's on the lock screen every time.
What's happening here? Is it the battery? (As it was replaced due to me ruining the original when I tried to remove it) is it the screen itself??
Also, which areas do I need to check to try and figure out what's happened.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I think the power switch is short circuiting, causing the screen to cycle on and off.
这个答案有帮助吗?
得分 0
添加一条评论
could be also a battery issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 250
