跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
My phone won't turn on.
My phone was low battery (8%) before I went into work and after few time it become turned off and I tried to turn on my phone. I've had it plugged on the charger, my phone felt cold so I assumed it might be too low of a temperature or something and it's been over an hour of the same response whenever I try to power up.
Did my battery damage or something? It hasn't happened before.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I don't know about this phone in particular, but my phone was run over 3 times and the logic board didn't get damaged, so I don't think that would occur with your phone (don't quote me on this though). If it is an old phone, it could be the battery just finally gave out as they do. If you're curious, here is what causes them do give out eventually:
http://batteryuniversity.com/learn/artic...
My best advice would be to take a look at this teardown, but note that it has a repair ability score of 2/10, which is unfortunate. You can also take a look at the battery replacement as well.
HTC One (M8) Teardown
HTC One M8 更换电池
HTC One M8图片
指南
难度:
中等
HTC One M8 电池图片
指南
HTC One M8 更换电池
难度:
中等
35 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ahmed masiul alam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 205
