跳转到主内容
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 个问题 查看全部
phone screen will not turn on
Hello, I just went to use my phone because it vibrated but the screen wont turn on. I can see the light at the top and when i press the home button the buttons next to it light up. ive tried hard resetting and it vibrates when it turns on but still no screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like the lcd is broken. I guess theres a chance it could be the connector or logic board but all the phones like yours Ive seen with that issue it has been the lcd. Usually happens after a fall or coming into contact with liquid or moisture even if it was days before. You could open it for inspection but if everything looks ok then the only way I know to find out is to hook up another screen that you know is good.
这个答案有帮助吗?
得分 0
1条评论:
@ripper i just got the screen replaced last week. I did just put a new audio jack in the phone and after that the screen doesn't work but the phone is on because it makes noise and all that
完成的
添加一条评论
添加你的答案
hunter gibboney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 130
