跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Won't charge, says This accessory may not be supported.
So here's the story; phone poorly taken apart, damaged chips, managed to get it to work but won't charge. One of the charging ics which I forget the name (9 pins, MOSFET, controls charging) was missing and had 3 ripped pads. Replaced that, now phones recognises charger bit says this accessory may not be supported, before would not recognise it at all. Not showing on pc at all. What should I replace next?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hey Giga, I just noticed this question. If you haven't fixed this yet, please let me know which IC exactly you replaced so that I can help you out.
完成的
添加一条评论
3个答案
已选择的解决方案
@refectio i just used the board as a donor, used almost all the parts.
这个答案有帮助吗?
得分 2
1条评论:
Cool, at least you put it to good use.
完成的
添加一条评论
1. Remove any debris from the charging port on the bottom of your device.
2. Restart your iOS device.
3. Try a different USB cable or charger.
4. Make sure that you have the latest version of iOS.
5. Contact Apple Support to set up service.
这个答案有帮助吗?
得分 0
3条评论:
No, read the OPs original post. He took it apart and messed with the internals. It has nothing to do with a dirty charge port or bad cable/charger.
完成的
This is unforunately the help you get in Apple forums.... a generic stupid easy answer that doesn't answer any of your questions.
完成的
Apple support is always giving basic unrealistic solutions to your problem, where in the world did you need latest software to have a well charging phone?
完成的
添加一条评论
I Absolutely agree John
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 44,082
