跳转到主内容
The Samsung WB150F is a 14 megapixel camera with 18x optical zoom and Wi-Fi connectivity.
14 个问题 查看全部
Repair damaged card slot, get card error, when card was put into slot.
Card sticks in slot. Will not come out without force. Can slot be replaced? Email address: hendersonc14@yahoo.com.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The SD card slot can be replaced by soldering in a new one. You can find SD card slots on digikey / mouser. Make sure to check the PCB pad dimensions for the broken sd slot and the replacement one. Also, make sure you are using the correct tips on your soldering iron, and that it is powerful enough for desoldering.
An example of a replacement microSD slot:
https://www.digikey.com/catalog/en/partg...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
charles hank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 67
