跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Major curtains after Touch IC replacement
Hi community. I posted on here the othwr day about issues when replacing a touch IC then losing the whole phone to shorts.
I thought i would post up what has happened after nearly all repairs i have dome to see if anyone else has had the same problem and may know what it is. I have never got a new batch of chips (due to trying to find a new supplier and buying 'new' but never getting new) so its always my first suspect, but has anyone else had this problwm and it ended up being something else??
(No its not the screen being the issue)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
So i put another chip on this morning, put the screen on again and there was less curtains.
The screen was fine prior to the repair, but when i tested it on another device it had the same pattern. Put a new screen on and it was crystal clear and had touch back :)
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I use microsolderingsupply.com haven't had any issues
这个答案有帮助吗?
得分 1
添加一条评论
I have never seen a touch ic complication that was due to a bad chip. Take off meson and see if you have normal display. This is almost certainly a technique problem.
这个答案有帮助吗?
得分 0
1条评论:
Slammed by my idol lol and even after my flex donation!! Haha
The chips they sent me were all reballed. Some where missing balls and had chips out of thr side.
I will try again tomorrow and see how i go
完成的
添加一条评论
I've had that issue with Meson IC purchased from Mengtor
这个答案有帮助吗?
得分 0
添加一条评论
Are you jumping pad m1 from the via?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacob Harvey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 152
