跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
798 个问题 查看全部
iPod in a constant state of charging, post-battery replacement.
I recently cracked the screen on my 30 gig iPod Video, and decided that it was time to swap out the slowly dying battery while I was in there.
Both repairs seemed to go just fine, and as soon as I plugged in the iPod, the Apple logo popped up, and all seemed well.
I let it charge overnight, to make sure the new battery had a good base. However the next morning, it said it was still charging.
I unplugged the iPod for a moment, to see if it was a connection thing. It gave me an estimated 50% battery charge.
So, I plugged it back in, restored and updated the iPod through iTunes, re-synced it, (which went fine,) and gave it all day to soak up power. but I've still got the little battery-and-lightning-bolt charging screen.
I haven't disconnected it again; I'd like to avoid stressing the battery by pulling it off the charger again before it gets a good initial charge. So I don't know how full it thinks it is right now.
Is this likely a bad battery? I just received it in the mail from iFixit yesterday. Could it be something else? It had no such charging issues before the repair. The battery life was just meagre.
Oh, and I've considered trying the old battery again, to see if it'll take a full charge. I just wanted to see what other options there were before I cracked it open again.
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
is the mAh rating on the replacement battery greater than the mAh rating for the OEM battery? if so, your ipod may never correctly assess the battery status, although it will hold a charge longer than before.
完成的
添加一条评论
4个答案
最有帮助的答案
Sounds like a faulty battery (I doubt its a logic board issue as it can hold a charge at least), I'd contact iFixit about getting a return/replacement.
这个答案有帮助吗?
得分 1
添加一条评论
I agree with rab777hp, it sounds like a battery issue. Iam waiting for my replacement battery from iFixit as well, hope all goes well. Also leaving any device with a rechargable battery for long periods of time is not a good idea. Unless the charger has a peak charger where the charger will shut off automatically, do not leave the battery unattended. This will just ruin the battery sooner. Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
iPods do not correctly report the charge status of batteries with mAh ratings > stock.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem too, post replacement battery, i tought i cracked something that might be the problem.
So, is it the new battery issue?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
darthstevious 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,991
