跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
My iPhone is stuck in boot loop
i just plugged by 4s into my computer and pressed the power butten and it gets stuck
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
my iphone 4s stuck on itune logo when i turn it on
完成的
添加一条评论
3个答案
已选择的解决方案
Your device is stuck on restore mode. You need to restore your iPhone using 3utools to exit this mode.
But if you select the option to retain the data, it would not always succeed.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Reset the device seems to be the main option, since it's more likely a software issue.
Note: This will remove all the data inside the unit.
With ITunes open
Leave the cable plugged into the computer and disconnect the other end from the phone.
Shut off the device
-If this cannot be done, do a restart by pressing the power button and home button at the same time.
Once the unit is off hold down the home button and plug the usb into the phone.
That should trigger the restoration process (Itunes and USB Logo should appear after plugging the usb). Restore and update the phone to most current OS.
Hope this helps
这个答案有帮助吗?
得分 1
3条评论:
can you do it without deleting the data?
完成的
and it also is still stuck
完成的
I can't think of, or know of, any software that can extract data from a unit. Sorry.
完成的
添加一条评论
Does it display the Apple logo for a sec and then reboot again?
Update (09/08/2017)
If it never gets to the Apple logo then it's probably dead from a power standpoint. If it won't power on at all, or only via external power it will boot to the Apple logo and then power itself back off (and eventually back on again), then it's detecting a fault of some sort on the boot up (i.e. when you see the Apple logo it's doing a sort of pre-flight systems checklist).
I saw this sort of thing on three iPhones over the summer (4S, 5, and 5S) - and of the two I've fixed so far, one (the 5) required a new battery, and the other (4S) I was able to get going again by charging it with an Apple cable and charger.
The issue in my case with the 4S was that it had run down so far that the phone thought the battery had gone bad. There are more severe hardware issues that can cause this sort of thing, and as well there are potential software issues that a hard reset might resolve, but for me 2 out of 3 of these (so far) were either bad or over-drained batteries.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
McOfficialPlayYT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 80
总计 14,757
